16 years agoThe component name specified in the MegaWizard must match the component name used in the declarative part of the architecture. As I previously mentioned, both component definition and and instantiation template generated by the Megawizard should be copied.
I'm sure, that you can figure out the right method by "trial and error". A VHDL text book or tutorial could be a shortcut, I think.
