16 years agoNo problem. If you insert the MegaWizard generated instantiation template, you have this code in your architecture body.
pll1_inst : pll1 PORT MAP (
areset => areset_sig,
inclk0 => inclk0_sig,
c0 => c0_sig,
locked => locked_sig
); areset and locked are optional signals enabled by default, you don't need them most likely. inclk0_sig should be connected to your clock (you can place the input port signal on the right side of the assignment directly) and c0_sig is your PLL generated clock. Of course, the signal must be defined in the architecture.
