quartus_pfg --info .pof Fatal Error
I would like to verify the payload is encrypted in the .pof file that I created.
I manage to get information on the .sof file (before encryption), but I fail to get information on the .pof file (after encryption):
N6010_4_1_0_8/work/syn/syn_top/output_files$ quartus_pfg --info ofs_top.sof
Info: *******************************************************************
Info: Running Quartus Prime Programming File Generator
Info: Version 23.1.0 Build 115 03/30/2023 Patches 0.02iofs,0.23 SC Pro Edition
Info: Copyright (C) 2023 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Thu Mar 27 15:18:54 2025
Info: System process ID: 49963
Info: Command: quartus_pfg --info ofs_top.sof
General
Device name: AGFB014R24A2E2V
Software version: Quartus Prime Version 23.1.0 Build 115 03/30/2023 Patches 0.02iofs,0.23 SC Pro Edition Patches .02iofs,.23
JTAG user code: 0xFFFFFFFF
Configuration clock source: 125 MHz OSC_CLK_1 pin
Configuration
Configuration scheme: AVST x8
Active serial clock source: 115 MHz Clock Frequency
Remote system update MAX_RETRY count: 1
HPS present: FALSE
Configuration Pin Options
SDM_IO0: PWRMGT_SCL
SDM_IO1: AVSTx8_DATA2
SDM_IO2: AVSTx8_DATA0
SDM_IO3: AVSTx8_DATA3
SDM_IO4: AVSTx8_DATA1
SDM_IO5: INIT_DONE
SDM_IO6: AVSTx8_DATA4
SDM_IO7: NA
SDM_IO8: AVSTx8_READY
SDM_IO9: nCATTRIP
SDM_IO10: AVSTx8_DATA7
SDM_IO11: AVSTx8_VALID
SDM_IO12: PWRMGT_ALERT
SDM_IO13: AVSTx8_DATA5
SDM_IO14: AVSTx8_CLK
SDM_IO15: AVSTx8_DATA6
SDM_IO16: PWRMGT_SDA
Power Management & VID
Version: 1
VID enable: TRUE
VID mode of operation: PMBUS_SLAVE
Device address in PMBus Slave mode (Hex): 3C
Error Detection CRC
Enable error detection check: TRUE
Minimum SEU interval: 479
Enable internal scrubbing: FALSE
Allow SEU fault injection: FALSE
CvP settings
Configuration via Protocol: OFF
Partial Reconfiguration
POF0 region ID: 0x01000000
POF0 hash: 7511807749D8142C00B755A59D39F7CFD906CA2996FF886E9561108547F1EEF8
Security
Enable configuration bitstream authentication: TRUE
Owner root key hash: AF777CCF 32DCD190 4E2D4C21 1E70ACB7 8D7114D7 D83FF895 BB830B1B 533823B1 F5302D6A 1C9DA4B1 22539468 3B160451
Enable multi-authority: FALSE
Enable configuration bitstream encryption: TRUE
Encryption key storage location: EFUSE
Encryption update ratio: 31:1
Enable scrambling: TRUE
Anti-Tamper
Anti-tamper response: DISABLE
Attestation
CRL distribution point:
Security Options
Disable JTAG: OFF
Force SDM clock to internal oscillator: OFF
Force encryption key update: OFF
Disable virtual eFuses: OFF
Lock security eFuses: OFF
Disable HPS debug: OFF
Disable encryption key in eFuses: OFF
Disable encryption key in BBRAM: OFF
Disable Intrinsic ID PUF-wrapped encryption key in Quad SPI: OFF
Tiles
P-tile: USED
E-tile: USED
Info: Quartus Prime Programming File Generator was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 1810 megabytes
Info: Processing ended: Thu Mar 27 15:18:59 2025
Info: Elapsed time: 00:00:05
N6010_4_1_0_8/work/syn/syn_top/output_files$ quartus_pfg --info ofs_top.pof
Info: Processing started: Thu Mar 27 15:19:31 2025
Info: System process ID: 49980
Info: Command: quartus_pfg --info ofs_top.pof
*** Fatal Error: Segment Violation: faulting address=0x44e9dd24, PC=0x7f4ef16f2c9e : 0x7f4ef16f2c9e: jtag_client!mem_prim_move + 0x18e
Module: quartus_pfg
Stack Trace:
Err Handler 0x136c2: ERR_UNWINDER_BACKTRACE::get_stack_trace(void const**, int, int, void*) + 0xe0 (ccl_err)
Err Handler 0x902d4: msg_ie_get_call_stack(void*) + 0xc4 (ccl_msg)
Err Handler 0x9220e: MSG_INTERNAL_ERROR::report_fatal(char const*, void*, bool) + 0x40 (ccl_msg)
Err Handler 0x170cf: err_report_fatal_exception(char const*, void*, bool) + 0x60 (ccl_err)
Err Handler 0x1736f: err_sigaction_handler + 0x191 (ccl_err)
System 0x42520: (c)
Quartus 0x24c9e: mem_prim_move + 0x18e (jtag_client)
Quartus 0x24522: memcpy_s + 0x172 (jtag_client)
Quartus 0x161843: PGMTCL_FILE_PARSER_POF::get_file_info(std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > > > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > > > > > >&) + 0x203 (pgm_pgmtcl)
Quartus 0x13832f: PGMTCL_FILE_PARSER::get_file_info(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&) + 0x5f (pgm_pgmtcl)
Quartus 0x42845f: PFG_CMD_FRAMEWORK::show_file_info() + 0x695 (quartus_pfg)
Quartus 0x435ab9: PFG_CMD_FRAMEWORK::execute() + 0x83 (quartus_pfg)
Quartus 0x34625: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0xf77 (comp_qexe)
Quartus 0x426ed8: pfg_cmd_main(int, char const**) + 0x5a (quartus_pfg)
Quartus 0x4e5c0: msg_main_thread(void*) + 0x10 (ccl_msg)
Quartus 0x50b07: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg)
Quartus 0x1f568: mem_thread_wrapper(void* (*)(void*), void*) + 0x98 (ccl_mem)
Quartus 0x10f58: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
Quartus 0xba55: thr_thread_wrapper + 0x15 (ccl_thr)
Quartus 0x4f6f4: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd3 (ccl_msg)
Quartus 0x426484: main + 0x26 (quartus_pfg)
System 0x29d90: (c)
System 0x29e40: __libc_start_main + 0x80 (c)
Quartus 0x40ba89: _start + 0x29 (quartus_pfg)
End-trace
- WZ2
Hi there,
Is this POF directly converted from a SOF? Does it include any additional binary files, such as a .hex file for the HPS or others?
Typically, a POF is not suitable for use with the quartus_pfg --info command. However, if the original SOF is trusted, the POF generated using the PFG tool is usually not problematic.
WZ
- Ariel_Morali
If the POF is not suitable for use with the quartus_pfg --info command, can you suggest another way to verify the bitstream is encrypted?
The files are created using the OFS build_flash.sh script, while ofs_top_pof_flash.pfg was modified to enable encryption.
Specifically, The pof is created with "quartus_pfg -c ofs_top_pof_flash.pfg".
This is the content of ofs_top_pof_flash.pfg:
<pfg version="1">
<settings custom_db_dir="./" mode="AVSTX8"/>
<output_files>
<output_file name="ofs_top" directory="output_files/" type="POF">
<file_options/>
<secondary_file type="MAP" name="ofs_top_pof">
<file_options/>
</secondary_file>
<flash_device_id>Flash_Device_1</flash_device_id>
</output_file>
</output_files>
<bitstreams>
<bitstream id="Bitstream_1">
<path signing="ON" finalize_encryption="1" qek_file="keys/aes_root.qek" password="keys/passphrase.txt" signing_pem_file="keys/ac_adp_dev_fim_root_private_384.pem">output_files/ofs_top.sof</path>
</bitstream>
</bitstreams>
<raw_files>
<raw_file type="HEX" id="Info_Factory_1">./factory_image_info.hex</raw_file>
<raw_file type="HEX" id="Info_User_1">./user1_image_info.hex</raw_file>
<raw_file type="HEX" id="Info_User_2">./user2_image_info.hex</raw_file>
<raw_file type="RBF" id="VAB_Option_Bits_File">./vab_option_bits.bin</raw_file>
</raw_files>
<flash_devices>
<flash_device type="CFI_2Gb" id="Flash_Device_1">
<partition reserved="1" fixed_s_addr="0" s_addr="auto" e_addr="auto" fixed_e_addr="0" id="OPTIONS" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x00010000" e_addr="auto" fixed_e_addr="0" id="Option_Bits_VAB" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x00020000" e_addr="auto" fixed_e_addr="0" id="Factory_Image" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x04000000" e_addr="auto" fixed_e_addr="0" id="User_Image_1" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x07FF6000" e_addr="auto" fixed_e_addr="0" id="factory_image_info" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x07FF7000" e_addr="auto" fixed_e_addr="0" id="user1_image_info" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x07FF8000" e_addr="auto" fixed_e_addr="0" id="user2_image_info" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x08000000" e_addr="auto" fixed_e_addr="0" id="User_Image_2" size="0"/>
</flash_device>
</flash_devices>
<assignments>
<assignment page="1" partition_id="User_Image_1">
<bitstream_id>Bitstream_1</bitstream_id>
</assignment>
<assignment page="2" partition_id="User_Image_2">
</assignment>
<assignment page="0" partition_id="Factory_Image">
</assignment>
<assignment partition_id="factory_image_info">
<raw_file_id>Info_Factory_1</raw_file_id>
</assignment>
<assignment partition_id="user1_image_info">
<raw_file_id>Info_User_1</raw_file_id>
</assignment>
<assignment partition_id="user2_image_info">
<raw_file_id>Info_User_2</raw_file_id>
</assignment>
<assignment partition_id="Option_Bits_VAB">
<raw_file_id>VAB_Option_Bits_File</raw_file_id>
</assignment>
</assignments>
</pfg>
- WZ2
From the .pfg file, it can be seen that the .pof was generated with encryption enabled, so it is indeed not possible to analyze it. I suggest you analyze the ofs_top.sof file directly instead.
