DLaff
6 years agoQuartus_map.exe is running out of memory (~50 GB) with an SRAM initialization file
I am trying to synthesize a 64 KB on-chip SRAM (used as a ROM for holding the bootloader for the arm MPU) for a Cyclone V, with an Intel Hex format initialization file. The system requirements for th...
DLaff
6 years agoI ended up solving this problem by changing the Type 04 Record as mentioned above, but was not able to successfully boot the preloader from FPGA SRAM. I altered the design to just use an SD card, which works.
Thank you.
