9 years agoQuartus main window is blank (Linux)
Hi, I attached PNG file of a problem I'm having, I just installed Quartus on my Linux CentOS 7 machine and when I start it, I get just a blank window frame with the title "Quartus Prime Standard Edition". I'm running this on a remote server, using VNC server and Gnome.
System information: CentOs 7.4.1708 kernel 3.10.0-693.2.2.el7.x86_64 Anyone see anything like this before? I'm new to Quartus and never encountered anything like this before. EDIT: I think Gnome is the problem, tried starting up a new vnc display using kde and it worked. If anyone knows how to get this to work with Gnome, please comment!3 Replies
This might related with the dependencies on your CentOs itself. Do you have xmonad package installed? Kindly see below link for further information: http://hackage.haskell.org/package/xmonad So, in you CentOS, I assume you can use yum search xmonad to list out related packages and then do a yum install <packages_name> then restart your Quartus tools. More open source command here: https://wiki.haskell.org/xmonad/installing_xmonad#fedora Best Regards, Joseph Cheah (This message was posted on behalf of Intel Corporation) - Altera_Forum
I have the same issue.
I work around it with : - a second VNC session on a differernt system. - connect with an ssh connection to the machine on which I run quartus - redirecting the display on the ssh session to the other VNC. Both machines are on Centos 6 2.6.32-642.11.1.el6.x86_64# 1 SMP Fri Nov 18 19:25:05 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux - Altera_Forum
I have a blank "License Setup Required" gui. Could you mention the sequence of exact commands to execute to make this work
