9 years agoQuartus main window is blank (Linux)
Hi, I attached PNG file of a problem I'm having, I just installed Quartus on my Linux CentOS 7 machine and when I start it, I get just a blank window frame with the title "Quartus Prime Standard Edit...
9 years agoHi,
This might related with the dependencies on your CentOs itself. Do you have xmonad package installed? Kindly see below link for further information: http://hackage.haskell.org/package/xmonad So, in you CentOS, I assume you can use yum search xmonad to list out related packages and then do a yum install <packages_name> then restart your Quartus tools. More open source command here: https://wiki.haskell.org/xmonad/installing_xmonad#fedora Best Regards, Joseph Cheah (This message was posted on behalf of Intel Corporation)
