9 years agoQuartus main window is blank (Linux)
Hi, I attached PNG file of a problem I'm having, I just installed Quartus on my Linux CentOS 7 machine and when I start it, I get just a blank window frame with the title "Quartus Prime Standard Edit...
9 years agoI have the same issue.
I work around it with : - a second VNC session on a differernt system. - connect with an ssh connection to the machine on which I run quartus - redirecting the display on the ssh session to the other VNC. Both machines are on Centos 6 2.6.32-642.11.1.el6.x86_64# 1 SMP Fri Nov 18 19:25:05 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
