18 years ago
quartus limits
someone know what are the limits of quartus web edition (maximum number of code...dimension of .sof (or pof or similar...) file?
i know that modelsim web edition have 10,000 lines limit..it is right?
thanks...again :D
    There are no limits on design utilization. Just limits on which devices you can configure/program.
    No such limit as 10,000 lines in Quartus II. You can compile the VHDL code directly in Quartus II web edition and target a free device.
    I'm not sure but could be that in the WebEdition the compiling core is less efficient than in the licensed version. Slightly difference.
    Hi mugoni,
    --- Quote Start ---
    --- Quote End ---
    I think so. I remeber that I read such a detail in a pdf or a readme file. But I can't remember the file. :o
    Christian
    The differences are detailed at
    http://www.altera.com/products/software/products/quartus2web/features/sof-quarweb_features.html
    In short,
    - To use Logiclock and Logicprobe in the web edition you must turn on talkback.
    - The web edition is missing the IPS-BASE suite of IP cores, the FIFO Partitioner megacore, LogicLock, the incremental flow, Hardcopy, and high-end parts
    For the Modelsim AE (or "Altera Edition", which is free for a limited time) there is a slow-down loop that kicks in once your design passes an unspecified threshold, however it will still compile. Also, some of the advanced diagnostic modules present in Modelsim SE (the full-blown product as purchased from Mentor) are disabled or missing in Modelsim AE. Modelsim AE is also a single language simulator, requiring you to specify either Verilog or VHDL when you initially order a license.
