PSchl7
2 years agoQuartus "Launch Simulation Library Compiler" Errors
Hello We are using "Quartus Prime Pro Edition" Version 23.2.0 Build 94 06/14/2023 SC Pro Edition. We are trying to compile simulation libraries for Questasim 2023.1 for VHDL under "Quartus> Tool...
RichardT_altera
2 years agoDoes the same error occur with Verilog option?
Do you also see the same error with the latest Quartus Pro version 24.1?
Are you using the Siemen Questasim or the Questa Intel FPGA Edition?
Questa Intel FPGA Edition seems to works fine.
Richard Tan
- PSchl72 years ago
Hello Richard
Many thanks for your answer.
I did rerun the compiler with the Verilog option on and did use Siemens Questasim. It then passes without any errors.
Guess this is the way we have to use the "Simulation Library Compiler" in future.
Peter
