16 years agoThere´s certainly a PLL inside the DDR2 controller. So the clk input of the controller leads to the PLL. I can´t check on a short notice it for you, because the controller doesn´t show up in my IP list. Probably there´s something misconfigured over here. Maybe someone else can help you for this.You are using SOPC builder I suppose?
Good luck, Ton
