Quartus is not recognising the Stratix 10 chip on my Stratix 10 development kit.
While using the programmer to program a design onto my Stratix 10 via USB-Blaster, the JTAG chain picks up the Max V on the board and picks up the Stratix 10 as an unknown device with JTAG ID 032250DD. This ID is within the pgm_parts.txt file in the Quartus directory under a lot of products. I've tried lots of things but still can't program the board.
- AndyN
Which Quartus version are you using? Are there multiple versions installed on the computer you're using? If you have older versions installed, I'd suggest uninstalling them first to make sure you have a "clean" set-up with an up-to-date programmer install...
Andy
- Vicky1
Have you installed the USB-Blaster Driver properly?
Refer the below link & try to reinstall also follow the steps carefully suggested here for connection to board,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr.pdf
Check Default Switch and Jumper Settings,
https://www.intel.com/content/www/us/en/programmable/documentation/sbg1472836198964.html
Best Regards
Vikas Jathar
- app_engineer
I reconnected my previous Stratix10 board which has power issues and was able to notice that the JTAG ID code is different.The board that I am trying to debug in this thread has the info:
Info (213045): Using programming cable "USB-BlasterII [1-2.3]"
1) USB-BlasterII [1-2.3]
020A40DD 5M(1270ZF324|2210Z)/EPM2210
C32250DD 1SG280HH1(.|S3|AS)/1SG280HH2/..V/S the old board which has the info:
032250DD 1SG280HH(1S1|2S1|3S1)/..Is this information helpful. Can you help move forward.
- Ranjith21
Hello @Daire_C_Intel,
I am running into the same issue on my board. Can I know what was the solution that worked for you?
That would be helpful
Ranjith
