SKon1's avatar
SKon1
7 years ago
Quartus IP SDC files
I'm using a Native PHY Transceiver in my Arria V design.
The IP is generated successfully - but I can't see any SDC files generated with it...do I have to write the timing constraints for it myself ?
  • Abe's avatar
    Abe
    When generating the PHY, click the EDA Options button and select the Generate Netlist option. Now, generate the PHY IP again. This time you will find the SDC generated.
  • SKon1's avatar
    SKon1
    Abe,
    I checked the generate netlist box and regenerated the PHY - can't see any .SDC in the folder
  • SKon1's avatar
    SKon1
    KYeoh,
    I see the SDC section for the Arria V.
    Can't find any "set_output_delay" constraints for the data output.
    It's basically only false paths...am I missing something ?
  • SKon1's avatar
    SKon1
    Did you see the document ?
    I could see only false_path constrains in it...is that all that's required ?
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    Yes. You just need to create clock and set false path to those asynchronous path.
