SKon1
7 years agoQuartus IP SDC files
Hello, I'm using a Native PHY Transceiver in my Arria V design. The IP is generated successfully - but I can't see any SDC files generated with it...do I have to write the timing constraints for it...
Abe
7 years agoHi,
When generating the PHY, click the EDA Options button and select the Generate Netlist option. Now, generate the PHY IP again. This time you will find the SDC generated.
