13 years agoThere is no random number in Quartus. Given the same input, it always gives the same output. (But even the smallest change will cause a different result).
Part of the reason you get variation is that the solution space is so large. Look at: http://www.alterawiki.com/wiki/the_quartus_ii_fitter_and_seed_sweeps So the two paths have different placement. One goes to a LAB that is both an X and Y hop away(basically diagonal) and hence a row and column hop are both necessary. The second one is placed in the same row and therefore only needs a single short line. The placement and route will be different compile to compile, so it's really not possible to compare a sub-portion of the path, as the fitter is working on the whole path. Also note that you have an adder, so there are multiple signals going into the carry-chain, and may not always be able to put them into the LAB right next to the carry-chain.
