Quartus install on Ubuntu
Hi JSYOO,
When running the installer, can I suggest not to put ' --target tmp_download '. Instead just run the installer as usual, you may change the desire specified directory in the installer afterwards
Example as below:
I think this will solve your problem. Let me know does it works for your case and if you have further inquiries do not hesitate to ask me
Hubert
Hi Hubert,
I am still facing similar issues without the target specification.
I wasn't sure where is the default extract location is, so I did not do the "sudo ./qinst.sh --help" with the new target location.
But, as you can see in the screenshot, I am still getting the "Aborted" message after doing "sudo ./qinst-linux-23.3-104.run"
The screenshot:
By the way, I could not see your image under "example as below:" line.
So I just removed the target part and did the "sudo ./qinst-linux-23.3-104.run" command.
Junsang
