13 years agoQuartus II Web Edition not communicating with USB-Blaster on OpenSuSe 12.1
I have succesfully installed Quartus II Web Edition 12.0sp2 on OpenSuSe KDE4 12.1 x86_64.
Quartus II is working in 32 bit operation. (not configured as 64bit during installation) I have an sample project succesfully compiled without any errors on Quartus II. But when i try to programm the .sof file to my EP3C25 Starterboard, the programmer doesn't show the USB-Blaster in the programmer configure window. If I start de command "hwinfo --usb" by terminal in su mode I get the following output info; 14: USB 00.0: 0000 Unclassified device [Created at usb.122] Unique ID: ZmS7.7UPKMDz+LLB Parent ID: 7eqy.v+N+B0xY+P6 SysFS ID: /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0 SysFS BusID: 6-1:1.0 Hardware Class: unknown Model: "Altera USB-Blaster" Hotplug: USB Vendor: usb 0x09fb "Altera" Device: usb 0x6001 "USB-Blaster" Revision: "4.00" Serial ID: "91d28408" Speed: 12 Mbps Module Alias: "usb:v09FBp6001d0400dc00dsc00dp00icFFiscFFipFF" Config Status: cfg=no, avail=yes, need=no, active=unknown Attached to:# 8 (Hub) So far conclusion SuSe is detecting the USB-Blaster But when I start the command "jtagconfig" I get the following message; hkopp64@linux-y0kk:~/altera/12.0sp2/quartus/bin> jtagconfig *** The Quartus II software cannot be started because the current platform, 'linux64', does not appear to be installed in: '/home/hkopp64/altera/12.0sp2/quartus'. Error (Server error) when scanning hardware hkopp64@linux-y0kk:~/altera/12.0sp2/quartus/bin> Quartus II jtag programmer is pointing to a 64bit dir, but how can I correct this to get the programmer working with the USB-Blaster into 32 bit operation ? Kind Regards Huib :confused:
