14 years ago --- Quote Start --- Like it says, in 10.0 the Cyclone 4 part you are using is for advanced compiles only. you need a newer version of Quartus to get it to work. WHats wrong with Q11? --- Quote End --- So there is no other way I can proceed with Quartus ver10.0 for the 22k logic part? The problem with ver11 is the PCIe-endpoint core will not work, can't detect by PC. Previously I tried modify my project with Quartus version 11, after I regenerate the SOPC, re-compile the codes, and program it into the FPGA on the Cyclone4GX starter kit. I plug the kit to a PCIe slot on a PC. The PC cannot detect the kit, the PCIe-endpoint core is not functioning. With version 10, the PCIe-endpoint core is working and the PC can detect the kit. The legacy project (where I leverage my code from) is also created using version10, and is used on the 15k logic FPGA. Can I use version 11 open my project file, then change the device to 22k logic and recompile the project, but without regenerate the SOPC, then program it into the 22k logic FPGA. Will this trick work??
