13 years agoI don't know if this would help you.
I'm using the Linux version of WebEdition on a 64bit environment. The WebEdition version is 32 bits only, and the jtagd was looking for 64bit version which, of course, wasn't installed. I realized the file <altera install directory>/12.0/quartus/adm/qenv.sh is used to set up environment variables and near line 90 the following test is done: if test `uname -m` = "x86_64" ; then export QUARTUS_BIT_TYPE=64 fi I commented these three lines and jtagd seems to work fine for me. # FIXME# FIXME# FIXME# FIXME# FIXME# FIXME # WORKAROUND ONLY FOR ME. # I commented the 3 next lines because # I'm using the WebEdition Version on a 64Bit # environment. # FIXME# FIXME# FIXME# FIXME# FIXME# FIXME # if test `uname -m` = "x86_64" ; then # export QUARTUS_BIT_TYPE=64 # fi
