15 years ago
Quartus II V10.1 Bull5hit.. Why?
Hi to all,
we have been using the Quartus II Software for over years. Mainly we use the schmematic entry and our designs grow and grow...
But now, in QII V10.1, the schematic entry is the greatest bull5hit Altera has ever done. Why is that so? Is there a Xilinx Engineer in
the Altera QII-Team to sabotage this software?
Some examples:
1. Copy-Paste wires with names in BDF-Editor.
If you press CTRL-C on a marked wire, the signal name is cleared... you must then press ESC followed by a new CTRL-C
to copy the signal.
2. The Symbol files are totally different from the older ones, if they exists...
If you update a symbol file, created with QII-9.2 or earlier, the symbol is so different that you can completely redesign your schematic.
On heavy projects there is no place, so its really hard work.
3. Copy-Paste from instances is totally disordered.
If you copy an instance, normaly the copy has a new, unique instance name. In Q10.1 some times Quartus don't increase the instance number.
So you get two or more blocks with the same name... That ends in compile failure and total chaos...
4. Auto Portnumber increase.
If you add a Port, QII in earlier versions has automatically increased an index after the name. In V10.1 not...
5. tbc....
Has none here the same problems? We have to use this version because we want to use the Cyclone IV GX chips.....
But we decide to test Xilinx. Is that the way Altera wants to go?
I hope this thread will not be censored :-)
Marco
