12 years agoQuartus II TCL: Analyze vhd files in a directory using quartus_map executable
Hello, I would like to analyze specific vhd files in a directory, not all of the design files (as part of an incremental compilation flow). I tried to use --analyze_file option of the quar...
11 years agoThe following appears to work for me, if what you are aiming for is to only analyse the file for syntax and or logic errors.
quartus_map --64bit --no_banner not_a_project --family="xxx" --part=yyy --set=HDL_INTERFACE_OUTPUT_PATH=./test_compile --generate_hdl_interface=zzz.vhd --source=zzz.vhd I learned how to do this by looking at what the analyse files button in the QSYS component editor does.
