11 years ago --- Quote Start --- I have just installed Quartus II (Subscription Edition with a license) V 13.1.0.(Build 162) on CentOS. Why am I unable to select Stratix V GX from the devices under Device Familly when I try to create a new project? We have been struggling with this for days now. The only devices available to select are the Cyclone , Max and Arria devices. Thanks in advance for any help with this. --- Quote End --- Did you install the Stratix V devices when you did the installation? There are two devices ISO images when you did the installation. The Stratix V should have been part of the first Devices DVD (which had the Cylone and MAX devices. Arria are part of the second DVD. So you installed both DVD's worth, but it's possible that you had the Stratix V unchecked. The other possibility, is the device file was corrupted (if you downloaded directly), so it failed to install the Stratix V family. I've seen this happen before, but it always gave me an error during the installation. I have 13.1.3 build 178 installed (13.1.0 is build 162) under Ubuntu 12.04 and I see the Stratix V with no issues. In your instatllation path you should see [install-path]/quartus/common/devinfo/stratixv directory. This directory should have all the various support files for the family. Regards Pete
