11 years agoQuartus II Ripping Out Logic
I'm trying to understand why Quartus is ripping out my logic. I'm trying to implement a microprocessor bus interface to an ARM based part, and I kept getting notes about being unable to find my clock pins. As I dug into it, I found it was saying that my clock input wasn't driving any logic. I've stripped everything out and have it down to a dummy piece of RTL and I'm still seeing my clock ripped out.
library ieee;use ieee.std_logic_1164.all;
entity dummy is
port
fpga_clk : in std_logic;
fpga_rst : in std_logic;
fpga_led_tp : out std_logic_vector(5 downto 0)
end entity dummy;
library ieee;
use ieee.numeric_std.all;
architecture rtl of dummy is
signal sysrst : std_logic;
signal sysrstn : std_logic;
signal reset_count : integer range 0 to 20;
begin
rst_con : process(fpga_clk)
begin
if ( rising_edge(fpga_clk) ) then
if ( fpga_rst = '0' ) then
sysrst <= '1';
reset_count <= 0;
else
if ( reset_count < 20 ) then
reset_count <= reset_count + 1;
else
sysrst <= '1';
end if;
end if;
end if;
end process rst_con;
sysrstn <= not(sysrst);
fpga_led_tp <= (others => sysrstn);
end architecture rtl; And the RTL viewer shows the clock and all the logic as expected (see the attachment--I can't seem to get Chrome to properly operate with an embedded image). But when I run the compilation, I end up seeing:Info (12127): Elaborating entity "dummy" for the top level hierarchy Warning (13024): Output pins are stuck at VCC or GND Warning (13410): Pin "fpga_led_tp[0]" is stuck at GND Warning (13410): Pin "fpga_led_tp[1]" is stuck at GND Warning (13410): Pin "fpga_led_tp[2]" is stuck at GND Warning (13410): Pin "fpga_led_tp[3]" is stuck at GND Warning (13410): Pin "fpga_led_tp[4]" is stuck at GND Warning (13410): Pin "fpga_led_tp[5]" is stuck at GND Info (17049): 5 registers lost all their fanouts during netlist optimizations. Info (16010): Generating hard_block partition "hard_block:auto_generated_inst" Info (16011): Adding 0 node(s), including 0 DDIO, 0 PLL, 0 transceiver and 0 LCELL Warning (21074): Design contains 2 input pin(s) that do not drive logic Warning (15610): No output dependent on input pin "fpga_rst" Warning (15610): No output dependent on input pin "fpga_clk" Which doesn't make any sense at all. Clearly fpga_led_tp is NOT driven by a constant, and fpga_rst and fpga_clk ARE driving logic! Any idea what is going on? Attached is the full log file. (Edit: I'm using "Quartus II 64-Bit Version 14.0.2 Build 209 9/17/2014 SJ Full Version" on Kubuntu 14.04)
