Jake,
I really appreciate the time you are taking to answer here.
But it seems that this discussion is not going anywhere.
--- Quote Start ---
By inconsistencies I believe you mean "doesn't behave like ISE"
--- Quote End ---
I don't think I ever said or inferred that Quartus should behave like ISE. I actually did not mentioned Xilinx or ISE before you did.
--- Quote Start ---
What version of Quartus II are you using?
--- Quote End ---
I mentioned in the initial post:
--- Quote Start ---
I recently installed the latest Quartus II 8.0 SP1
--- Quote End ---
When I say inconsistencies I really mean inconsistencies with Quartus itself:
1. Instantiation template for Verilog but not for VHDL. Does it have to be ISE to treat both languages equally?
2. I thought "Analyze Current File" really means analyzing only the current file (and the modules instantiated in it). I was looking for clarification. What's wrong with this? Does it have to be ISE to do what it says?
3. Is it ISE'ish to be able to generate a test bench template for any module in a project?
Look, I understand you are a very experienced user, but not everyone is like you. Different people prefer different ways of doing the same thing (more or less productive).
--- Quote Start ---
If there is something I can do to help reduce your learning curve, let me know.
--- Quote End ---
The best way to help is to discuss about what was asked and provide a solution or work around if possible.
Assuming things is usually not productive.
Thank you!
BR
