15 years agoHi,
you can use the Quartus II MegaWizard Plug-In Manager to create your ram. In the Megawizard: Select Memory Compiler and then the RAM: 2-Port Configure yout Port Width and generate the Ram. The Result is a VHDL component declaration File for your RAM and the VHDL Code for the RAM. You can use the VHDL Code in your Programm or generate a sheet symbol to use the RAM in your schematic.
