Altera_ForumHonored Contributor18 years agoQuartus II I/O bank voltage settings Running into a problem when allowing quartus to set I/O bank voltage. Particularlly 1.8V The tool generates the following in the .qsf set_instance_assignment -name IO_STANDARD "1.8 V" -to ra...Show More
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
