12 years agoOne of the possible root causes of this IE is that your design contains Receiver Only channel with Rate Match being turned on. Rate Match FIFO is clocked by the clock from the transmitter channel of the same physical location, therefore, if the use of Rate Match FIFO is intended, you will need to create a duplex channel. Otherwise, just disable the Rate Match FIFO.
Let me know if this works.
