12 years agoQuartus II Internal Error -- Please Help!
I am using Quartus II 64 Bit Version 13.0 for my project on the Arria V GX Starter Board. I am designing a transceiver which would accept 1.25gbps stream of data and see if the data violates the 8b/10b encoding scheme. I have created "Arria V Transceiver Native PHY", "Transceiver PHY Reset Controller" and "Transceiver Reconfiguration Controller" modules and am trying to instantiate them all in the top level entity file called "top". However, during simulation I am running into the error given below. I would really appreciate it if someone could help me out with the problem. I can provide more info as necessary.
--- Quote Start --- Internal Error: Sub-system: CUT, File: /quartus/db/cut/cut_arriav_hssi_pcs_coreclk_legality.cpp, Line: 536 local_tx_pcs_atom != NULL Stack Trace: 0x461401: CUT_ARRIAV_HSSI_PCS_CORECLK_LEGALITY::report_rmfifo_mode_bad_rx_coreclk_source + 0xf1 0x461bef: CUT_ARRIAV_HSSI_PCS_CORECLK_LEGALITY::check_pcs_8g_rx_coreclk + 0x29f 0x461d8b: CUT_ARRIAV_HSSI_PCS_CORECLK_LEGALITY::are_coreclk_connections_valid + 0xcb 0x85b56: hssi_fpp_create_module + 0x192c6 0x1c3e6: FSV_U2B_POSTFIT::operator= + 0x8226 0x12ee1: fsv_execute + 0x2a11 0x13c45: fsv_execute + 0x3775 0x104f2: fsv_execute + 0x22 0xb959: fmain_start + 0x7e9 0x2225: Legacy_fitter_Init + 0x11b5 0x1ea8: Legacy_fitter_Init + 0xe38 0x2e68: Legacy_fitter_Init + 0x1df8 0xf8a6: TclInvokeStringCommand + 0xc6 0x112a8: TclEvalObjvInternal + 0x328 0x121b5: TclEvalEx + 0x8d5 0x12d48: TclEvalObjEx + 0x2d8 0x1abbd: Tcl_EvalObjCmd + 0xfd 0x112a8: TclEvalObjvInternal + 0x328 0x56917: TclExecuteByteCode + 0xe47 0xa2376: TclObjInterpProcCore + 0x76 0x112a8: TclEvalObjvInternal + 0x328 0x56917: TclExecuteByteCode + 0xe47 0xa2376: TclObjInterpProcCore + 0x76 0x112a8: TclEvalObjvInternal + 0x328 0x121b5: TclEvalEx + 0x8d5 0x7c117: Tcl_FSEvalFileEx + 0x1d7 0x7a626: Tcl_EvalFile + 0x36 0xbd5f: qexe_ipc_progress_bar_name + 0xf3f 0x11498: qexe_get_command_line + 0x1068 0x147a5: qexe_run_tcl_option + 0x585 0x1dacd: qcu_run_tcl_option + 0xb8d 0x14dbd: qexe_process_cmdline_arguments + 0x54d 0x14f21: qexe_standard_main + 0xa1 0x4ae8: msg_exe_fini + 0x58 0x522c: msg_exe_fini + 0x79c 0x1524: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194 0x5e0f: msg_exe_main + 0x8f 0x1652c: BaseThreadInitThunk + 0xc 0x2c520: RtlUserThreadStart + 0x20 End-trace Quartus II 64-Bit Version 13.0.0 Build 156 04/24/2013 SJ Full Version --- Quote End ---
