14 years ago
Quartus II installation question on RedHat 5.5 x64
New install Quartus II 11.1 on RedHat Enterprise Linux Client 5.5 x64
Progress bar shoots to 100% instantly, and spit out a message box:
--- Quote Start ---
Failed to register the Quartus II Subscription Edition (Paid) software. The registration executable '.../altera/11.1/quartus/bin/qreg' does not exist.
--- Quote End ---
Maybe I'm not supposed to use RedHat 5.5;
[root@localhost bin]# uname -a
Linux localhost.localdomain 2.6.18-194.el5# 1 SMP Tue Mar 16 21:52:39 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux
Anyone seen this before, please comment,
Thanks a lot.:D
I don't have it installed yet
Just found out how to use 64-bit Quartus II modules, post link here:
http://quartushelp.altera.com/current/mergedprojects/global/install/install_pro_64bit.htm
    Got online installation moving by using the altera_installer.external.sh
    :confused:
    But seems it's the easiest way to get it moving for my situation.
    Just got Quartus II (11.1) running on RHEL 5 x64
    Post my experience, wish it could be helpful for others
    First of all, install by using net installer (altera_installer.external.sh) which is on the top of the Quartus II download page. (side note: running standalone Quartus II subscribed .sh file, I didn't see SELinux warning at all, but complains of missing .../11.1/quartus/bin/qreg, could not more forward)
    After installation, saw quartus warning pop-ups about registration and jtag
    need to disable selinux or set it to permissible mode (security at own discretion)
    do the following:
    .../11.1/quartus/bin/# qreg --tb2id
    .../11.1/quartus/bin/# qreg --jtag
    Setup license by setting environment variable in .bashrc or .cshrc
    See http://quartushelp.altera.com/current/master.htm#mergedprojects/global/install/install_pro_specify_lm_license_file.htm (http://quartushelp.altera.com/current/master.htm#mergedprojects/global/install/install_pro_specify_lm_license_file.htm)
    After installation is done, one can turn SELinux back on, but all Quartus II *.so libraries needs to be added to allow list:
    Do this by:
    .../11.1/quartus/linux/# chcon -t textrel_shlib_t *.so"
    Note do above line strictly from the linux folder, since chcon -t textrel_shlib_t '.../altera/.../*.so' doesn't accept file name wildcard.
    Actually there is a Altera Solution ID for this: spr329499 (see Support Knowledge Base)
    Can try to start Quartus II, if you see "failed with: Internal Error: Sub-system: ATCL ... "
    set SELinux in permissible mode, reboot and test
    If your Quartus II starts when SELinux in permissible mode, repeat "chcon"
    Cheers,
    Hi all,
    From Altera websites, it seems that they only provide support for RHEL 5.0/6.0. How about sub-versions for RHEL i.e (RHEL 5.4 or RHEL 6.1)? Do they officially support these subversions if we run into errors?
