18 years ago --- Quote Start --- I always have one folder or folders (containing a collection of previously used and debugged modules) containing the code and as many projects for variants or for debugging modules as I need. If designed carefully a lot of VHDL can be re-usable. Don't know if this is standard or good practice as I am self taught. --- Quote End --- This is much like what I do. I have one folder that contains my source code and simulation files, usually called ./project/src/ I have folders underneath .src/ that control the revisions of my codeset (e.g. src/v0_10, src/c0_20, src/1_00 with 0_ numbers being pre-release and 1_ styled number being post release) I have another folder that contains the build files for whatever fpga technology I am using, usually called ./project/par. That folder also contains individual folders that track the version numbers in the /src/ folders. Both Altera and others have ways to make revisions, which Brad just wrote about and those are fine, too. I do not use them only because I have my own system independent of the big A and the big X. BR
