15 years ago
Quartus II change version
I developed a project using Quartus II version 9.1 and incremental compilation.
Now I would like to use version 10.1 I installed the software but whrn I started a compilation Quartus did a complete compilation: a new sintesys, new merge and new fitting...
How is it possible to avoid this I just want to use the new software verson to contonue my job, not to statr again from scratch...
Please help me.
Stefano
1 Reply
    Hi, (not necessarily) look at quartus 10.1 in this forum ;-)
    In Quartus 9.1, check the "export_db" (compatible database exportation) option in settings. This will create, at compilation under Quartus 9.1, a "export_db" directory.
    In Quartus 10.1 (and newer, and even older ;-) ), you can open the project and it will ask you for an compatible database which is the "export_db" directory.
    May it help you. Good luck
