17 years agoQuartus II 7.2 Crashes
I'm getting the following error trying to export a vector waveform file (.vwf) into a VHDL test bench file (.vht) in Quartus II 7.2
Internal Error: Sub-system: TBO, File: /quartus/neto/tbo/tbo_common_vec_writer.cpp, Line: 512 bus_port->has_type() Stack Trace: End-trace Quartus II Version 7.2 Build 151 09/26/2007 SJ Full Version It's familiar to you? Should i attach the .vwf file? Thanks
