11 years agoQuartus II 4.0 - Start Complilation Disabled
I am sorry if this has been posted before. I trying to compile VHDL code using Altera Quartus II 4.0, web edition, and for some reason compilation option is disabled. I also installed latest version 14.0 to see it that works but same problem. I will using Windows 8 x64. Any ideas what is going on. http://s23.postimg.org/hvi6sce3v/Quartus_II_Can_t_Compile.png7 Replies
Quartus 4.0 is not supported on win 8.1. Why are you using an 11 year old version of quartus?
It came with a book that is why I used that version. But latter I installed latest version as can be seen below. In the second image I have the same problem.
http://s7.postimg.org/dl7e0at4r/Quartus_II_14_0.png http://s7.postimg.org/ojinihhq3/Quartus_II_14_0_Can_t_Compile.png - Altera_Forum
I installed Quartus II 4.0 on VMware Workstation running Windows XP Pro SP3, here also I have the same issue.
http://s3.postimg.org/kw1g3mxhv/VMWare_Can_t_Compile.png - Altera_Forum
Have you created a project, or just opened the VHDL files?
You need a project to be able to compile. BTW: if thats the code that came with the book (johns.vhd) - I would ditch that book and find one that uses much better code examples (the code is quite poor). - Altera_Forum
--- Quote Start --- Have you created a project, or just opened the VHDL files? You need a project to be able to compile. BTW: if thats the code that came with the book (johns.vhd) - I would ditch that book and find one that uses much better code examples (the code is quite poor). --- Quote End --- Thanks, that was exactly it, I needed to create a project first. I was able to compile the file. Regarding, johns.vhd, the code is definitely written poorly but it is not from the book, I found it online. Now that I compiled the file I want to do a functional simulation where I face another problem, as seen below. I searched for that error and one suggested to add file to the top-level. But it is already in top level. Any ideas what is going on? http://s15.postimg.org/lh4w5p9mz/Error.png - Altera_Forum
Hi thebatosai,
Sorry if I have missed out anything. What is the error with compilation that you are encountering? I mean the Quartus II error message. - Altera_Forum
Are you using the vwf for the simulation?
