11 years agoQuartus II 4.0 - Start Complilation Disabled
Hi, I am sorry if this has been posted before. I trying to compile VHDL code using Altera Quartus II 4.0, web edition, and for some reason compilation option is disabled. I also installed lates...
11 years ago --- Quote Start --- Have you created a project, or just opened the VHDL files? You need a project to be able to compile. BTW: if thats the code that came with the book (johns.vhd) - I would ditch that book and find one that uses much better code examples (the code is quite poor). --- Quote End --- Thanks, that was exactly it, I needed to create a project first. I was able to compile the file. Regarding, johns.vhd, the code is definitely written poorly but it is not from the book, I found it online. Now that I compiled the file I want to do a functional simulation where I face another problem, as seen below. I searched for that error and one suggested to add file to the top-level. But it is already in top level. Any ideas what is going on? http://s15.postimg.org/lh4w5p9mz/Error.png
