Quartus ii 14.1 sp1 download needed
That version is no longer available for download.
13.0sp1 and 13.1 are because they support some legacy devices.
17.0 and later the next older versions available.
Altera used to leave all the older versions available for download, but after the transition to Intel the policy is now to deprecate most older software.
Is there some reason you need exactly 14.1sp1?
- NateW4 years ago
ak6dn,
thanks for your response. Yes, I need that exact version of Quartus II because we are using CVP and have units whose I/O ring cannot be updated and that was the version used to create the I/O ring.
Thank you!
- ak6dn4 years ago
Well, the only responses I have seen in the past when this issue comes up is you need to have an Intel Premier Support account (meaning you are a large and valued customer) and make a special request thru that account. Premier Accounts are not given out willy nilly, you have to have a special business relationship to Intel.
IMHO you need to update to a newer version and recreate those aspects of your design, you are chasing a rainbow.
And then make sure you SAVE all the downloaded install files for that Quartus version. Don't just install and delete.
Good luck.
- fisher21 year ago
no funcina mi latop
