10 years agoQuartus II 12.1 EPCQ16 check ID issue
Hi I'm using Quartus II 12.1 and i want to write an EPCQ16 device with jic file. I read that i have to disable the ID memory check but in the Convert Programming File tool the option "Disable ...
10 years ago --- Quote Start --- "Disable EPCS ID check" is (typically) not selected by default. You need to select that check-box so that it has a tick in it to disable the ID check. Newer versions of Quartus have "Disable EPCS/EPCQ ID check" - a little clearer. Cheers, Alex --- Quote End --- Thanks Alex, I'd like to select the check box but the graphical tool is disabled. It is impossible to click on it.
