10 years agoQuartus II 12.1 EPCQ16 check ID issue
Hi I'm using Quartus II 12.1 and i want to write an EPCQ16 device with jic file. I read that i have to disable the ID memory check but in the Convert Programming File tool the option "Disable ...
10 years ago"Disable EPCS ID check" is (typically) not selected by default. You need to select that check-box so that it has a tick in it to disable the ID check.
Newer versions of Quartus have "Disable EPCS/EPCQ ID check" - a little clearer. Cheers, Alex
