15 years agoQuartus II 10.0 SP1 to 10.1 - Timing Worse?
I have two similar designs using Cyclone II and I found that timing requirements could be comfortably met in our designs with QII 10.0 SP1.
Since 10.1 just came out, I upgraded to it and found to my dismay that timing went out the window. Not just a bit, but quite a few nets not meeting requirements by a mile. I fiddled with some obvious settings, such as increasing the effort to meet timing, with marginal improvement and overall still failing. Suspiciously, v. 10.1 finishes the build much faster, even when I set high effort. It's as if QII decided to slack off... Now, this can be due to a bad alignment of the planets (i.e. the specifics of the design and the actual changes to QII) but I'm just wondering if anybody has seen something similar. If you have or if you have some other relevant thoughts, would you mind briefly responding here? Thanks! In the end, I can just stay with 10.0 but I did want to use the latest version. I'm just not looking forward to wasting time with more serious tweaking, unless I REALLY have to. Sandor
