16 years ago --- Quote Start --- Hi GPK I use pre-synthesis taps. So they shouldn't be synthesized away (as I'm observing them). Anyway, from a functional point of view, the signals are toggling (I see the register input with usefull value, but the register don't get it, and I see the input at 1 when fixing it to 1, and the the register takes in the '1' as soon as reset is released...). Odd isn't it? Regards, Peter --- Quote End --- Hi Peter, you can see the input signal of register in Signaltap and could not see in signaltap the right output of the register ??? Can you post your code or the Quartus project here, so that I can have a look to it ? Kind regards GPK
