11 years agoQuartus II - Setting Global Clock Input (MAXII)
I am doing a design with an Altera part (EMP240T100I5) using Quartus II. I'm pretty inexperienced with the architecture and software, but have learned enough to have been able to get a few designs programmed and running. I have been using the internal oscillator up to now, but this new design requires using a global clock input. I thought implementing a global clock input would be relatively straightforward, but have been pulling my hair out on how exactly this is done. I've searched around a lot, and am now more confused than ever. Some of the resources seem to imply that the TimeQuest Analyzer is used for this purposes, but to me this seems more about giving the software data for timing analysis and less about actually implementing the clock. Other resources said to "set that pin as *global*", but I have not been able to find out where this might be done in the GUI. (Yet other resources seemed to explain how to do it via command line, but I'm more comfortable with the GUI - I figure the GUI should be able to handle this.) Yet other resources explain how to set an internally generated signal to a global net. All the information I find seems to be either overly complex (for my knowledge level on the subject) or else only tangentially applicable to my query (with advanced descriptions meant to generalize the process at the expense of clarity). All I want to do is tell the software that pin 12 (GCLK0), named "CLK", is a global clock input. (And also where to specify the timing constraints based on this selection.) Does anybody know of any resources that break this process down into simple steps? Additional Information: - Software: Quartus II 12.1 SP 1.33 (32 bit) - Device: EPM240T100I5N (MAXII) - Computer: Windows XP (SP3) - Language: VHDL (1993) Thank you.
