11 years agoThe MAX II devices have global clock inputs pre-assigned. What you need to do is make sure your external global clock signal connects to that pin, i.e., in your case assigning CLK to GCLK0 (pin 12) is sufficient.
The Cyclone Handbook page has links to the pin configurations guidelines. Read through that and it explains the pin functions. Cheers, Dave
