14 years ago
Quartus-II - Error: Can't place multiple pins assigned to pin location Pin_D11 (IOC_X
I'm using Quartus-II V8.1 with a Stratix-II (EP2S15F484C3) and trying to compile a very
simple application and getting the error:
Error: Can't place multiple pins assigned to pin location Pin_D11 (IOC_X15_Y27_N0)
Info: Pin TEST_INP is assigned to pin location Pin_D11 (IOC_X15_Y27_N0)
Info: Pin ~nCSO~ is assigned to pin location Pin_D11 (IOC_X15_Y27_N0)
The application has four pins defined. Two input and two output pins, such as:
INPUT (PIN_AA18) ---> OUTPUT (PIN_U12)
TEST_INP (PIN_D11) ---> TEST_OUT (PIN_D12)
I went to "Assignments->Device->Device and Pin Options->Dual-Purpose Pins" and tried
to change "ASDO,nCSO" to "Use as regular I/O", but appears as if the only option
is "As input tri-stated"
The configuration is set to "Active Serial" using a EPCS64 configuration device. The board
has this configuration device.
Also, the pin (D11) is defined as an input pin in the design. Does anyone know of a
solution (other than not using the pin)?
Any help is appreciated. Thanks!
