15 years agoThose are defaults(definitely TDS, but not sure about Optimize Hold Timing). There are a ton of assignments, but if you start a new project you'll note that the .qsf is almost empty. Only as you go to non-standard settings do they appear. (I believe is something is already in the .qsf and you change it to a default, it won't get removed). So, for example, if you want to see Timing Driven Synthesis show up, turn it off in the GUI, save the project, then turn it back on and save the project.
(It can be annoying, but I've seen old versions where every possible assignment is listed. There's a reason it was disabled, as everyone complained...)
