Quartus FPGA Development Software 22.1 Lite crashes in Signal Tap
I am using Quartus 22.1 Lite software. I has been working fine until I try to set the Signal Tap Trigger flow control to "State-base". When I set it to State-base instead of Sequential, the entire program crashes. This does not happen with Quartus 20.1 or 20.1.1 . Is there a fix for this or do I need to just use one of the earlier versions of Quartus???
- SyafieqS
Bill,
I'm checking this with developer. Will let you know once there is any update.
Seem for now you have to use 20.1.1 Lite as I am getting feedback for this.
- SyafieqS
Hi William,
From IPS has Created Case 00774316 - ARROW ELECTRONICS, INC - Quartus Lite STP [5003b00001jXjflx0] by Robert Polk, the agent support is currently investigating and feedback the same issue to developer. Thus I will follow up from there and let you know any update.
- SyafieqS
Hi William,
Engineering team is still investigating this problem. I'll let you know of any updates.
- SyafieqS
I am pending update regarding this issue from the IPS created.
- IntelSupport
Contributor
Hi William,
Seem this issue has been idling and replicate with the IPS filed by the DFAE, perhaps you may follow up the update from there as I will close the ticket here and you can workaround it using 20.1.1.
Let me know if there is any concern on this.
I am apologize for the inconvenience caused.
