WShep1
Contributor
3 years agoQuartus FPGA Development Software 22.1 Lite crashes in Signal Tap
I am using Quartus 22.1 Lite software. I has been working fine until I try to set the Signal Tap Trigger flow control to "State-base". When I set it to State-base instead of Sequential, the entire ...
IntelSupport
Contributor
3 years agoHi William,
Seem this issue has been idling and replicate with the IPS filed by the DFAE, perhaps you may follow up the update from there as I will close the ticket here and you can workaround it using 20.1.1.
Let me know if there is any concern on this.
I am apologize for the inconvenience caused.
