sorry but i still have a little problem;
my new code is:
ibrary ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity deserializer is
--- {{{ interface signals declaration
port(
--- {{{ system clock
sclk : in std_logic; -- 270 Mhz deserializer clock. Deserializes data into 2-bit words.
pclk : in std_logic; -- 27 Mhz word rate clock.
reset : in std_logic; -- Async active high reset
--- {{{ interface 1
data_in : in std_logic; -- 10-bit parallel unscrambled data in
--- {{{ interface 2
q : out std_logic_vector(9 downto 0) -- 1-bit deserialized data output.
--data_10b_out : out std_logic_vector(9 downto 0); -- 10-bit parallel unscrambled data in
end deserializer;
--- {{{ RTL Architecture Declaration
architecture STRUCTURE of deserializer is
--- {{{ internal signals declaration
signal inc : std_logic_vector (3 downto 0):="0000";
signal qs : std_logic_vector(9 downto 0) :="0000000000" ;
begin -- rtl
--- {{{ sequential process
-- purpose: sequential process
-- type : sequential
-- inputs : sclk, rst
-- outputs: q
sync_count : process(sclk,pclk, reset)
--variable inc : std_logic_vector (3 downto 0);
begin
if rising_edge(pclk) then
q<=qs ;
inc<="0000"; -- <--this coz me a problem in compilation (depends on differents clock edge)..where should i write it?
end if;
-- pour pouvoir synthètiser le bloc avec quartus
if (reset = '1') then
qs <= "0000000000";
elsif (rising_edge(sclk)) then
inc <= inc+1;
if (inc = "1001") then -- return to '0' when inc achieve '9'
inc <= "0000";
end if;
case inc is -- i is the counter in 0 to 9
when "0000" => qs(9) <= data_in;
when "0001" => qs(8) <= data_in;
when "0010" => qs(7) <= data_in;
when "0011" => qs(6) <= data_in;
when "0100" => qs(5) <= data_in;
when "0101" => qs(4) <= data_in;
when "0110" => qs(3) <= data_in;
when "0111" => qs(2) <= data_in;
when "1000" => qs(1) <= data_in;
when "1001" => qs(0) <= data_in;
when others => qs <= "0000000000";
end case;
end if;
end process sync_count;
end STRUCTURE;
how can i get inc="0000" at every rising edge of the pclk, because i would beginig counting at this rising of pclk clock?
thank you
