16 years ago --- Quote Start --- I'm very confused as to why the assignment made in the assignment editor did not work. This is exactly the same thing as using "altera_attribute" within the code. Did you make the assignment on a different entity when doing through the assignment editor vs. through the code? Jake --- Quote End --- Hi, It was the first time when I was using the assignment editor so that was probably the case. I'm not so good at using the GUI, but nevertheless your advice also helped. Thanks again. Benny
