Quartus doesn't recognize clocks generated by division of the same master clock as synchronous
Hello, when clock are divided small delay apply to output and transportation too.
Information about language and CPLD series is missing, exact error too.
Supposed you are using a ring divider or Johnson small delay is present from clock edge to FF Q output.
If you are using a standard counter delay come from logic too.
Please complete description to help address what happen.
Thanks for your reply. I am working with the MAX II family, an EPM570 cpld, and coding in Verilog.
Here is the error message:
Critical Warning (308060): (High) Rule D101: Data bits are not synchronized when transferred between asynchronous clock domains. (Value defined:2). Found 17 asynchronous clock domain interface structure(s) related to this rule.
I have my clocks defined in the sdc file as shown below. All are integer divisions of the same master and the dividers are synchronous counters. I changed the divisor on the last one just for the constraint because Quartus can't seem to deal with very slow clocks
create_clock -name {cpld_master_clock} -period 542.000 -waveform { 0.000 271.000 } [get_nets {cpld_master_clock}]
# Create Generated Clock
create_generated_clock -name {uart_rx_clock} -source [get_nets {cpld_master_clock}] -divide_by 2 -master_clock {cpld_master_clock} [get_registers {clock_divider:CDIV2|clk_out}]
create_generated_clock -name {uart_tx_clock} -source [get_nets {cpld_master_clock}] -divide_by 32 -master_clock {cpld_master_clock} [get_registers {clock_divider:CDIV3|clk_out}]
create_generated_clock -name {millisec_clock} -source [get_nets {cpld_master_clock}] -divide_by 1920 -master_clock {cpld_master_clock} [get_registers {clock_divider:CDIV4|clk_out}]
create_generated_clock -name {heartbeat_clock} -source [get_nets {cpld_master_clock}] -divide_by 3840 -master_clock {cpld_master_clock} [get_registers {clock_divider:CDIV5|clk_out}]
- RRomano0015 years ago
Contributor
No idea about code so see if this can help
or table
try also google for
or
Altera create_generated_clock -name {
First search add some solution from other vendor and generic forum can be of help understanding issue.
