RHobb
3 years agoQuartus disregards allocated RAM specification and num_processors ?
I have Quartus Prime Lite v. 21.1. I have a very large design that won't compile and exits (crashes) after 50 hours of compilation due to out of memory. I have listed to use 8 processors out of the 1...
AEsqu
Contributor
3 years agoHello,
I also use a Cyclone V (using Quartus Prime Version 22.1std.1 Build 917 02/14/2023 SC Standard Edition) under red hat 7,
I see this in the output_files/*.flow.rpt:
; Flow Elapsed Time ; +----------------------+--------------+-------------------------+---------------------+------------------------------------+ ; Module Name ; Elapsed Time ; Average Processors Used ; Peak Virtual Memory ; Total CPU Time (on all processors) ; +----------------------+--------------+-------------------------+---------------------+------------------------------------+ ; Analysis & Synthesis ; 00:07:18 ; 2.0 ; 2780 MB ; 00:10:16 ; ; Total ; 00:07:18 ; -- ; -- ; 00:10:16 ; +----------------------+--------------+-------------------------+---------------------+------------------------------------+
And as for the lsf jobs report, I see this:
------------------------------------------------------------ # LSBATCH: User input quartus_map wld_fpga_top ------------------------------------------------------------ Successfully completed. Resource usage summary: CPU time : 672.50 sec. Max Memory : 4694 MB Average Memory : 1754.22 MB Total Requested Memory : 3000.00 MB Delta Memory : -1694.00 MB Max Swap : - Max Processes : 9 Max Threads : 27 Run time : 501 sec. Turnaround time : 511 sec.
(I use in the .qsf set_global_assignment -name NUM_PARALLEL_PROCESSORS 6 )
I think the mapping phase is mostly using one or 2 CPU cores but It can use more during fitting phase (I will post it when I get the result).
As for the crash, I guess Quartus is stuck in a loop with your design, try to remove any timing constraint in the .sdc to see if this is not related to one of them.
