HituS's avatar
HituS
2 years ago
Quartus cut paste not working
We are using Quartus 23.3.pro and copy paste function is not working with it. If I open another Quartus window with another design, cut and paste sometimes(*1) works, but only for single blocks, Not for larger selections. I can also paste the single block in the other quartus window (the window where cut and paste never works). But after the paste action, I cannot cut and paste that block again in any window.
  • ArjanS's avatar
    ArjanS
    We've tried all suggestion above. Nothing seems to work.
    One day, for a short moment, things were working fine again. Copy and paste worked fine.
    But after 5 minutes things stopped working again and have not worked since then.
    I think something is blocking the clipboard from being filled, but have no idea what.
    Can there be any (group) policy installed on my machine that does something with the clipboard?
  • ArjanS's avatar
    ArjanS
    Laptop was replaced and Quartus ran fine for several months. Now the issue is back!
    Latest Quartus Lite Edition installed 23.1std.1, build 993, 64 bits. Running win11.
    Problem Details
    Error:
    *** Fatal Error: Access Violation at 00007FFC4596AA94
    Module: quartus.exe
    Stack Trace:
    0xbaa93: operator== + 0x3 (Qt5Core)
    0x1f1d6a: QMimeData::setData + 0x32a (Qt5Core)
    0x1f1f40: QMimeData::setImageData + 0x20 (Qt5Core)
    0x16678: AFCQ_DATA_TRANSFER_MANAGER::add_image_format_into_clipboard + 0x38 (GCL_AFCQ)
    0xb6b27: GEDQ_VIEW::add_bitmap_to_data_source + 0x337 (edt_gedq)
    0x2d765: GEDQ_COPY_COMMAND::execute + 0x635 (edt_gedq)
    0x5d4a5: GEDQ_FRAME_WND::on_copy_action + 0x445 (edt_gedq)
    0x1f3946: QObject::qt_static_metacall + 0x14b6 (Qt5Core)
    0x5dce: QAction::activate + 0x10e (Qt5Widgets)
    0x6d6a: QAction::event + 0x9a (Qt5Widgets)
    0x1483f: QApplicationPrivate::notify_helper + 0x10f (Qt5Widgets)
    0x138c2: QApplication::notify + 0x18b2 (Qt5Widgets)
    0x1d4439: QCoreApplication::notifyInternal2 + 0xb9 (Qt5Core)
    0x693de: QShortcutMap::dispatchEvent + 0x57e (Qt5Gui)
    0x6b889: QShortcutMap::tryShortcut + 0x79 (Qt5Gui)
    0x2d97e: QWindowSystemInterface::handleShortcutEvent + 0x17e (Qt5Gui)
    0x424ec: QGuiApplicationPrivate::processKeyEvent + 0x8c (Qt5Gui)
    0x2edff: QWindowSystemInterface::sendWindowSystemEvents + 0x8f (Qt5Gui)
    0x21d573: QEventDispatcherWin32::processEvents + 0x73 (Qt5Core)
    0x5a748: qt_plugin_query_metadata + 0x1ee8 (qwindows)
    0x1d086b: QEventLoop::exec + 0x1bb (Qt5Core)
    0x1d3403: QCoreApplication::exec + 0x153 (Qt5Core)
    0x10b1: qgq_main + 0x81 (quartus)
    0x12208: msg_main_thread + 0x18 (CCL_MSG)
    0x13b18: msg_thread_wrapper + 0x78 (CCL_MSG)
    0x15f13: mem_thread_wrapper + 0x73 (ccl_mem)
    0x11a41: msg_exe_main + 0xa1 (CCL_MSG)
    0x2076: WinMain + 0x156 (quartus)
    0x1659: __scrt_common_main_seh + 0x105 (quartus)
    0x1257c: BaseThreadInitThunk + 0x1c (KERNEL32)
    0x5af27: RtlUserThreadStart + 0x27 (ntdll)
    End-trace
    Anybody any idea what could cause this issue?
