JohnnyKwei
2 years agoQuartus copied content from IP directory then reported permission error
I am in IT and I am seeking help / discussion with Quartus software developers. I am not familiar with how to use your tool - again, I am in IT. The user experienced an issue and I knew the reason, ...
WZ2
2 years agoHi there
- For issues regarding Quartus license, you can find the relevant IP license in Quartus -> Tools -> License Set Up. It seems the customer is using the CXL_type2 IP, so you can check if there is a license labeled "CXL IP for Device Type2..." or similar. Alternatively, you can compare the license files between versions 23.4 and 24.1 to identify any differences.
- The log shows that you raised the issue in mid-June, but I am not sure where the remaining time has been spent.
- You can ask the customer to use the Quartus GUI to generate the error description and attach the error report.
WZ
